Hallo, ich bekomme per Email ein Hilfegesuch für ein Problem mit dem IFA W50.
Leider klappt die Kommunikation nicht so, eventuell kann ja jemand helfen?
Emailadresse: [EMAIL]darrieldriml100@yahoo.com[/EMAIL]
[QUOTE]hallo Renato,
I am having problem with my clutch on my IFA w50 . The clutch is nicht good. (video posted on youtube). It only has 9,000 km so I can't imagine I need a new one. would think it just needs to be adjusted. How can I do this? any help is appreciated!!
[/QUOTE]
[QUOTE]I tried to register on the IFA Tours site, but can't understand most of the form to fill out. will try again, I have tried twice and google can't seem to translate, sorry!
D
IFA-Tours wrote:
massdld schrieb:
> Hello Renato,
> The following is an email sent to you by massdld via your account on Steel Soldiers. If this message is spam, contains abusive or other comments you find offensive please contact the webmaster of the board at the following address:
> [EMAIL]support@steelsoldiers.com[/EMAIL]
> Include this full email (particularly the headers). Please note that the reply address to this email has been set to that of massdld.
> Message sent to you follows
> hallo Renato,
Hello
Could you announce yourself please under [URL]www.IFA-Tours.de[/URL] and ask your
question there in the forum?
There very many IFA W50 driver and specialist from Germany are also
English read and letters can. I can do it only with the help of
translator often commodity. If the IFA drove only 9,000 km, then the
clutch might be not yet worn.
Man can place these behind.
Greeting Renato
[/QUOTE]
American IFA W50 Clutch Problem (amerikanischer IFA W50 mit Kupplungsproblem)
- Mechanik IFA LKW W50
- Renato
Hello All, I am a relatively new IFA W50 Driver. I love my machine and I am obviously American and Speak No German. I apologize. I just bought it in January and am restyling it and it is in need of some help. Mainly the clutch stop working. There is very little mileage on the vehicle (9,000 KM) so I can't imagine it already needs a new clutch. Is there a simple adjustment that I can do to get it working again? There is no clutch right now. I put it in gear, let out the clutch and then nothing happens. It slowly started to go out on me on one of my drives until it finally stopped altogether. Any help would be appreciated. Thanks!! D
Hello
I had this Problem also. It should be possible to adjust the clutch at the bar between pedal and clutch mechanic. Sorry but i don´t have the right words for the technical parts. The clutch has to be adjusted for about all 3000 kms. -
Ich habe mal eine Bitte, wäre es möglich, das wenn wir hier in englisch schreiben, die deutsche Fassung mit dazu schreiben können? So können alle mithelfen, Danke
Hello
between clutch pedal an clutch are different tie rods with fork ends.
they are connected with bolt to the lever with bush and finaly to the operating shat of the clutch. all are saved by split pins. Move out the split pins an the bolts. The fork ends are saved with hexagon nuts. unsave it. Than rotate the fork ends on the tie rods an change the longness of the tie rod and so the way of the clutch.
on the clutch pedal it needs a free movment of 2,5 cm (may be 1 inch?) than the clutch start breaking the connection between motor and gearbox. I think you have to make the tie rod longer but I'm not sure.
It is always my problem when I adjust the tie rods: longer or not.May be the clutch works again. viel Erfolg
also hier noch mal in D:
Die Kupplung ist über Zugstangen mit Gabelenden mit dem Pedal verbunden. Die zugstangen sind über bolzen mit dem Hebel mit Buchsen und mit der Kupplungswelle verbunden.
Gesichert mit Splinten. Splinte und Bolzen rausnehmen und die Länge der zugstangen druch drehen der Gabelelnden ändern.
Spiel am kupplungspedal sollte 2,5 cm betragen.
Frage ist, müssen die zugstangen verlängert werden oder verkürzt. Ich glaube verlängert. habe aber jedes mal das gleiche Problem.
