I have an IFA W50 its 4x4. I have a problem with first gear and reverse gear. Its really hard to get it in those gears, and when i can put it in those gears, its very hard to get it out of gear and i hear a grinding noise. Maybe you can help me with some information?
IFA LKW W50 - Gearbox problem
- Mechanik IFA LKW W50
- djjoni2
Das kann an der Schaltbox liegen.
Es gibt eine Sperre, die verhindern soll, dass man ungewollt in den 1. Gang oder Rückwärtsgang gelangt.
It could be the switch box.
There is a lock to prevent accidental shifting into 1st or reverse gear.
Schaltbox neu abfetten und die Schaltung neu justieren.
Grease the switch box again and readjust the circuit.
Hi,
check please if your Clutch is working properly. First and reverse Gear are not synchronized and depending on, that the Gearbox inputshaft comes to a complete hold. That means if you operate the clutch, the small Propshaft between clutch and Gearbox should stop turning..
Reinhard
